Irritated
I have a guy that keeps on trying to get me to buy a cap instead of an extra battery. Whats the advantages and disadvantages of both?
Username: Solacedagony
New Jersey US
Post Number: 145
You should be buying a higher output alternator before either a cap or a battery if you need the extra juice.
A cap is going to smooth out your high juice spikes, but you're still actually loading up your alternator just as hard. The alternator is what makes the power that your car (and system) uses, not the battery, and not the cap. The battery and cap STORES the power for when you need it. Deep cycle batteries help cause they give a real flat output and can take a whole lot of abuse.
I have an HO Alt.
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 75
now just buy a battery. ITll do better than a cap. BUt if youre going to be entering contests then you would need to buy caps because you have to burp the car i n some comps with the car off so you get no help from your alternatro. So you would need batteries and caps. BUt if youre a daily driver, then i say just buy a deep cycle battery liek a optima yellow top since you already have a HO alternator
New Jersey US
Post Number: 146
Agreed basslova.
Username: Jonathan_f
GA USA
Post Number: 2775
I'd do the cap personally. The Battery will help mainly when the car is off, a cap helps control transient peaks and dips, something a battery cannot do. When the car is running and a voltage bias is applied all the battery does is charge anyway.
I was actaully thinking about getting a cap and a redtop for under the hood. How may farad cap do i need? I have a eD NINe.1 and a ed NINe.2 amp.
Username: Help_2
Post Number: 33
2 farad
You get 1 farad for every kw
Who makes good Caps?
