Custom Boxes for 2001 Grand Am SE
Username: Wolfdog22us
Post Number: 12
I bought 2 Infinity Kappa Perfect 10.1.d's and a Kenwood KAC-X520 Amp. I know what I want to do with them, just need some advice on setup (Enclosures) cause There is not much room to play with. The spare tire casing will be removed and the Amp will be installed there, but as far as the Subs Im leaning to custom Enclosures near the rear of the trunk around where the tailights are, facing toward the backseat. Does anyone have a Grand Am that might give me some Ideas?
http://www.cardomain.com/memberpage/369397/6
Username: Dnizzle
Raleigh, NC USA
Post Number: 28
If its facing towards the backseat it will sound lke crap
