What's the difference between Top Mount and Bottom Mount?
Username: Datboyp
Odessa, TX USA
Post Number: 20
What's the difference?
Also, I'm building my own box; what's an easy way to figure out how much internal volume the sub's magnet will take up?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6738
only difference is the amount of displacement the sub takes up inside the box.
bottom mount takes more room obviously.
as for actual displacement, it's listed in the TS parameters for the sub.
should come on a paper with the subs, or be available from the mfgr on their website
