Fuse question (a stupid one at that)
Username: Kklagge
If the amplifier has (2) 30A fuses is it okay to run an 80A inline fuse (have on hand) or should I go purchase a 60A fuse? (I don't want to have to drive anywhere in the middle of my install)
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 264
80 amp will be fine
Username: Kklagge
Thanks
Username: Carguy
Post Number: 873
Using 80A is not a wise decision. If you can, get 60A fuse.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6496
http://www.bcae1.com/fuses.htm
