Problem with the code in for Sony cdx-m630
Jimmy
I have a Sony cdx-m630 and I have no remote but as soon as I hook it up the face says "CODE IN"
Any help gettin around this?
Cheers.
Carl
Jimmy, sounds like to me that you lost your code. call sony and give them the serial # on the radio and they will give you the code over the phone. I had a problem with a blaupunkt one time with the code,i called them,gave them the serial#,i punched it in & was hooked up.the radio was given to me cause the guy didnt know the code.........good luck.
zacdavis
nice try, but you have to have the original receipt and store that you bought it from. if you bought it used ya might as well trash it, sorry, thats the truth, i've worked in car audio for years and the manufacturers even give us a hassle when trying to help our customers on the very same problem, hope you bought it new.later
I lost the code of my CDX-M630 .The remote doesn`t work.The serial is 20655317.Can you help me ?Thanks.
I also have the CDX-M630, came with the car, no remoth changed the fu**ing battery now can't us the stereo if anyone does have codes can you help.
psychedelic munter
This is classic - I need codes aswell for the CDX M360 - I'm guessing everyones scored them :-))
I have the code, but you need the original remote to enter it which i do not have. tell me the code for the remote (on the instruction book) and i'll tell you the code...
And i thought i was the only one, my cdx-m630 is also second hand[ so to speak], i've tried all the codes that i came across on the net, but struck no gold :-)
<hr>
Dr Love
does any one know how to put the code in the sony cdx-m630 with the remote controll
I have a cdx-630 with no instruction manual! Clueless how to set radio presets. Help??
Username: Amt2002
Try entering the following, using your remote control:
DISP
SOURCE
OPEN/CLOSE
1
This should work. Let us know.
der is a way of enterin the code without the remote i cant get it!! i have the code for the the remote one but no remote!!!!
sum1 help me!
djherpeze@campus.ie
The default code that comes with all manuals is the following.
on the remote press:
"mode" "sound" "open/close" "ATT".
Can you please send me the unlocking codes for the sony cdx-m630. i bought the car recently and had to take off the stereo to replace the dash display.I placed it back and it was displaying CODE IN. i also have the remote control.
thank
Username: Amt2002
erm, have you tried the codes provided above??
Another code is:
3
MENU
SEEK <<
OPEN/CLOSE
Bizze
i lost the yellow paper with the code on, are there any other codes for this player because these don't work :-(
sorry for my bad english, i'm from belgium
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2029
yes here's the code:
buyanewheadunit
the codes are there for a reason. to stop people (probably like you) from stealing the radio and using it without the codes.
I was just going to add that this remote (rmx-117 for the cdx-m630) is available straight over the counter at any good SONY dealer or is ordered and sent in three working days and they will sell it to you with no questions asked. Then when you get home you can punch the codes provided on this forum straight in to the remote and it will work. I did this and all is well with my CDX-M360. I was not treated like a theif as you obviously are on this forum.... I wanted to let ALL users know that help is available without prejudice. To the Member GLASS WOLF you are obviously a LAREDO DRIVIN wanker who thinks his excretement dont stink. Who are you to assume that because we dont have codes we are theives. Up you man, hope your junket of a vehicle gets ripped by the real thieves and burnt to a cinder. Help like yours is not help it's down right sarcasm. Who needs it. Hopefully in the future this forum will become the one I was looking for, a "help and Technical one" until then this is my first and last post.
Regards,
SED8ED.
XR2iguy
I agree with glasswolf most of you probably are fckin theiving bastrds who cant afford a decent headunit.
GET BENT MAN!!! YOU SUCK DOGS WEINERS. FOOL. GO SUCK OFF YA MUMMA. GLASS WOLF SUCKS AND SO DO YOU XR2iguy.
yo mamma
wow. real b*tchin. i thought this forum would gimme some help wi my stereo but instead i got some laughs. Good work.
Jai perdu le code de mon poste sony cdx m630 il faudrait absolument que je le recupere merci de m'aider
well hello there. i'm I girl from sweden that had the same problem just a few minutes ago. it took me three different codes to find the right one. NOW I`LL FOUND IT!!!! My stupid battery in the car failed down and when I got it started again my stereo crashed and asked for a code.
It was:
Mode
Sound
Open/close
ATT
Thank you all.
aghh, I like those swedish people, always thinking outside the square they live in. Nice to see that across the seas in other countries there are people who want to help rather than ridicule. Nice work!!!!!! I think there is a pattern emerging. GlassWolf your silence speaks volumes.
If anyone would like their radio decoded i will do it for them, mail me and i'll sort out some details.
Please help, i have the remote control but whith your codes my sony cdx-m630 doesn't work. Someone have the unlocking codes??
thank you thank you thank you
Hi all,
I've tried all the above codes for my m630. Another website says there are 15 available codes and 1 will work for each specific stereo. Problem is they don't seem to be replying. I've got my receipt, serial no and remote. It was a mate that pressed the reset button without asking me if I had the code! Has anyone got any suggestions as I can't go much longer with my stereo!!
Thanks
lost my code for cdx m630 took it out got it d coded no more probs
i can decode any sony unit that has lost codes, email me for more info, London area only please
Straight Cali
The reason for these post are to find help. If you (Glasswolf) can't be of any help. Then shut up!! Some of us end up buying a car that already has a stereo. Not realizing that it may be important to have the code just in case we replace the battery with a new one. Then you find out later that you have to have the code to work the stereo. Not everybody's a thief. Take your head out of your rear end. Most, if not all that replyed to the post did so to help one another. What the hell crawled up your a@#!!!
help me please iv have just sold my beloved head unit as igot a new car with a buit in one any way i sold it to some bloke thinking i could remember my code but of coarse iv forgot it is there any one who knows an over ride code as i have all ready had it uncoded once or is there any one in the nottingham area who can uncode it me please help
The thing I cant understand Is why no-one will list all the codes. If someone has all the codes Why not just post them. The unit is a couple of years old now and far from the breaking technology that is coming out now, there are heaps of second hand units floating around it is now obvious that people will be offloading these to upgrade and therefore the lost code situation is popping up.. It would probably have to be one of the only units I have owned with a low resale value purely because it has to be sold with a shitty code (I realise it's for security). It would have been better if you could have set this unit up to work with or without a code yourself and those who wanted a code could use the feature and those they knew they are forgetful could turn the feature off. If people are offerering d-coding they must know all the codes, why take advantage of people and offer decoding when you could list all the codes here anonymously. Are these people asking for money. Is decoding permanent??? Can anyone answer these questions for me????. I live in Australia and I do not know anyone who can decode the unit I have. Does anyone know what to do or where to go...Can someone e-mail me the codes for cash???? I would be prepared to pay to get the unit working again. obviously there is an easy remedy to this situation (forgetting where I put code). So I will ask the question, IS ANYONE PREPARED TO LIST OR TELL ME THE CODES...Do a google search and look at how many people are asking for these codes...Absoloutely heaps. Lets put them out of their misery regardless of the fact they may be thieves..I couldnt care less if they were, I just want my unit to work again. To hell with sony (this stuff is as bad as the minidisc software they offer).
I was wondering if anyone could tell me where to find a remote control for sony cdxm630 it would be greatly appreciated
hi all
cud some body please tell me how 2 link my cdx-m630 i hav no wiring instructions.
thanx
wiring for cdxm630
red - switched 12v
yellow - constant 12v
blue - control for amp/antenna
black - earth
gray - right front sp+
gray/blk - right front sp-
white - left front sp +
white/blk - left front sp-
violet - right rearsp+
violet/blk - right rear sp-
green - left rear sp+
green/blk - left rear sp-
code 3
menu
seek<<
open/close
does work with remote
anyone out there with the code for sony,s cdx-m630, I brought this piece of @#$%@ when I was on vacation in Germany, now I am back home in the caribbean,I hook it up in my hum-v all I am getting is code in. I have no remote control
HELP........
I have some codes.... Six to be precise and 2 of them definatley work. However the one i need i do not have. Email me @ beasty_simon@yahoo.co.uk and i'll exchange some codes.
For any that might be looking for the remote to buy I brought one from a guy in USA selling on eBay for just £15.00 maybe you could too. www.ebay.com just type rm-x117 in the search field. Good Luck. Would be really nice though if just one carefree person could share, (the ever so secret by dont really know why coz its old skool now!), 15 codes with me. I have 11 but none work for me. Gutted :-( Look forward to a reply thanks.
You need to press reset after each attempt.
CODE 1: MODE SOUND OPEN ATT
CODE 2: ENTER OPEN meNU 6
CODE 3: OPEN DISC+ 1 LIST
CODE 4: SEEK- SEEK+ 3 OPEN
CODE 5: OFF 4 OPEN SOURCE
CODE 6: 2 OPEN DSPL SOUND
CODE 7: OPEN 5 ATT SEEK+
CODE 8: DISC- DSPL OFF OPEN
CODE 9: SEEK+ SOUND OPEN ENTER
CODE 10: DISC- LIST SEEK- OPEN
CODE 11: OPEN 4 LIST OFF
CODE 12: DSPL SOURCE OPEN 1
CODE 13: MENU 2 MODE OPEN
CODE 14: 5 DISC+ OPEN ATT
CODE 15: 3 MENU SEEK- OPEN
hope they work for some of you, got them from sony last week!! need to convince them you are gen. They might ask for a copy of your passport, car reg number, address and serial number then they email you back quick time!!
is there any way to change a preset with out the remote?
Hi, can anyone help me, I have taken my old cd-player out of the car, and put the CDX-m630 in, but I dont know what I did wrong, cos now I have a problem, when I turn the key without start the engine, so only power starts, then cd-player works, but when I start the engine, than cd-player turns off, and then I cant start again no matter what I do, I need to take it out and put it again before it turns on again with power only, and goes off again when engine starts. What can the problem be? I have tried with 3 cd-players, and all of them turns off.
fred1001
to the tosser that thinks everyone is a thief,why are you so paranoid are you one trying to look innocent
Martin1111
Hi, can someone please tell me where the remote lead connects to from my amp to my sony CDX-m630
wHOOO HOOOOOO I am back on the road again... Thanks to the anonymous tipster!!! Tried all codes up to thirteen and whalla!!! Everything is running again...Funny thing is though when i saw the code (no 13) I was dead sure it was the one!! My memory has served my poorly but thanks to you anonymous tipster you have allowed me to gain control of the music.. Well done!!! I cant begin to express how happy i am. This unit cost me $800 (AUD) originally and i have gone without the music for three months. I feel like I just left the craziest rave on the planet.
Good luck all***
Fight for the music for free.
petur
Yeah, thanks for the codes - one of them worked for me and my unit is working again! Thanks from Iceland!
thanx my stero is working now thanks for the codes
Username: Rikithebest
hello!!!! I reset my cdx-m600r and now it wants the code! what is??? help me!! thanks
hi can someone help me , im trying to hook my sony cdx-m630 to my cd changer and all it said is "PUSH RESET" and i did 4 time still don't work im going crazy............do i need codes to make work?????
pipdaz
i was given a cdx m630 by a lad i work with but it has no remote and i dont want to pay for a new one if it wont work ive bin told ther a way arround this any help please
smith85
hi thankyou mate my stereo working now you a star!!!! mine was code 12!!!
JBlive
Thanks to the anonymous code man that sent out the codes. What a relief to finally have my music back.
