Help with wiring please!
Username: Corey01
Post Number: 10
hey everyone..i have two audiobahn dub500 series (800W RMS each) subs which are 2 ohm or 8 ohm operation. I have an audibahn A2200HCQ 2 channel amp, specifications: 200 watts x 2 @ 4 ohms stereo
400 watts x 2 @ 2 ohms stereo
650 watts x 2 @ 1 ohm stereo
1600 watts x 1 @1 ohms mono......what would be the best way to wire this system? i am prety new to this and it's gona be my first time wiring my own amp and subs so any help would be greatly appreciated!
Username: James1115
Ct
if your amp is stable at 1ohm then I would run the subs Parallel / Parallel at 1ohm and you would obtain your peak power out of your amp!
James
taylor17
Ya 650 watt's should sound good.
