Infinity kappa perfect or JL audio VR?
i am looking at a component set and speakers but im not sure which ones are better. I listen to rap but i like loud clean and clear sound. i am currently looking at infinity kappa perfect 6.1 comp set with kappa 692.5i 6x9 speakers... OR JL VR650-Csi comp set with TR690-Cxi 6x9 speakers. for a little while i will not be running an amp, just the sony head unit. is this bad for the speakers since the JL's rms is 15-100 and the infinity is 25-400 .. im not to sure exactly what the head unit will be pushing but im sure its not to much. let me know what you guys think id really appreciate it thanks.
Username: Jonathan_f
GA USA
Post Number: 2703
The head unit will not push either well, but if you keep it from clipping, the speakers will be fine. They just won't meet your "loud" requirement. If you like a crisper sound, the Infinities are for you, the JL VRs have a softer sound to them and are better if you'd want a little warmer neutral feel.
