L5 or L7???
Username: Trev87
Glennville, Georgia Usa
Post Number: 13
what is better a 12" L5 or a 10" L7? What has the most bass?
the L7 should be better, it also has more power handling then the L5. I'm not sure about the excursion but you can check that on kicker.com. Look and see which one has more "Xmax". The more xmax= more air= more bass
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 62
the best sub is the L7. It has a stronger motor than the 12" L7 and the 10" L7. not only does it have a stronger motor but 3 or 4 more millimeters more xmax
