F*cked up my brahma already
Username: Hdubb
Farmington, Nm Usa
Post Number: 150
ok. i was letting my friend put my brahma in its box, and the drill slipped off the screw and went straight through the foam! does any one have any ideas on how to fix it?
Sucubus
clear nail polish.
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1177
silicone...malleable and flexible enough to withstand the excursion
Username: Decde
Post Number: 278
100% silicone.
Nail polish will cover but will crack since it doesn't extend
trini_spl
Silicone emits acetic acid fumes when curing and those fumes are known to eat away foam surrounds...maybe while it's curing, u cud fan it or something
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6121
geesh
do not use silicone caulk. it will erode the foam.
use clear acrylic nail polish.
it will seal the tear if it's relatively small, and cover it from both sides.
yes it dries hard, but it seals the tear, and it's strong as can be.
I did the same thing over a decade ago to one of my CV subs, and fixed it with polish.
It's held since 1989 till now without fail, through numerous IASCA events and years of daily use.
Sucubus
Owned ;)
Hfl, Ny Usa
Post Number: 1179
i got compu served lol...
Username: Zacdavis~
Post Number: 316
wow, finally bacon and i agree:-)
(silicone)
Hfl, Ny Usa
Post Number: 1180
ahaha omg i never thought id see the day...
Help2
lol...he only agrees with you when youre wrong.
Im a dick, arent I?
Username: Decde
Post Number: 280
I just got b*tch slapped by wolf lol :P
Username: Chevy_for_life
Post Number: 257
!@#$%!#$% yea you did ..I always used Silicone.. never had anyproblems with it.. but i might try that nail polish next time..
Username: Glasswolf
Post Number: 6165
whatever works for you.
VirginSlayer2.0
yeah well if your ever gonna sale your stuff at the flea market.. and you used silicone watch out... the umm mexicans.. like to poke at it with their fingers until the hole tears back open if you dont watch em.. dirty.. dirty .*bastar**s... So go with the nail polish.
