Wiring dvc subs
Username: Mattyb789
if i was to bridge a fosgate 800.2 amp to one sub should i get a dual 4 ohm or dual 2 ohm ??? which one would be louder???
Username: Hdubb
Farmington, Nm Usa
Post Number: 156
i dont know rf amps, but if the amp is 1 ohm stable then go ahead with dual 2 if it isnt go with dual 4 ohm. this is because dual 2 ohms can only be wired to 1 or 4 ohms and if your amp isnt one ohm stable than it could be a waste. so check out your amp an d then make your choice
Help2
Its a 2 channel amp.
800x1 @4ohms.
get a dual 2 ohm sub, and wire it in series.
what kinda sub is it?
