Problem with pioneer
nnnnick b.
i have pioneer deh2600. When i turn the volume down to 00 there a rumbling sound from the subs like alternator noise b.c it changes with engine rpms. and when i turn the volume up from 00 to 01 there is a bump or pop in the subs. Also happens when i change sources. I just put a new ground on everything but that didnt work. please help.
nnnnick b.
bump
nnnnick b.
bump
nnnnick b.
BUMP BUMP BUMP
Username: Mr_kebo
Albertville, Al USA
Post Number: 20
I have the same excat problem with my setup!! Hopefully someone can help. I have also changed all my ground points.
Same here. Thinking maybe too much left over wire?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6176
ground loop.
