Help beating 13w7
i want to beat my friends single 13w7 in spl and sq. what would be a good choice? i was thinking maybe an 18" x.x.x. or a 15" braham. hes got a 13w7 and mtx1801d amp
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 64
if you want to beaT him in sq a 18" subwoofers wouldnt do the job. Get a 15" X.X.X in a ported box built to the spec. put some sound deadener in your trunk. With a bx1000 hifonics amp.Make you set your gainsand everything right and hopefully beat him. BUt it depends on the car. What kind of car does he drive and what kind of car do you drive. And is his box ported or not
we both have f 150 supercrews 2002, and hes got a ported box
Miami, FLORIDA USA
Post Number: 66
0o0o thenyou have to make sure you build your box to the exact spec that re gives you and you should win no doubt with the X.X.X
Username: Slap_johnson
Arizona
Post Number: 122
SQ's going to be tough to beat against that W7 if you want to beat him in SPL, vice versa, you could get 15" X.X.X, build a box to specs, and tune to about 27 hz
Username: Fordpwr
Los angeles, Ca Usa
Post Number: 27
does anyone know of a few amps i can use to power the 15" x.x.x.?
Username: Fordpwr
Los angeles, Ca Usa
Post Number: 28
help someone
Miami, FLORIDA USA
Post Number: 73
hifonics bx1500d
kicker kx1200
Username: Solacedagony
New Jersey US
Post Number: 142
If you're buying a good sub like that, and you have the money, get a good amp. USAmps have some pretty good deals on their stuff, considering the amount of power they give. I'd look at them. www.usamps.com I believe.
Username: Subfanatic
dude...go with like 2 12 inch eclipse ti..youll own his a$$...but...where and how can i get sound deadener...and how can i use it...my hatch in my camaro shakes like a mother f*cker...help me out
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6569
look on ebay, dan.
look for dynamat edead brown bread fatmat or any number of alternative less expensive alternatives to the real dynamat products.
ebay has great prices from folks on bulk materials like that, and the Ti subs are pretty on par with an RE triple X. I wouldn't go saying a Ti would beat the RE subs that quickly.
I've owned both, and presently use the RE subs in my competition vehicle.
Post Number: 7
yea i like the re's but i jhave the eclipses and i really would just say that in my opinion...not thats its a fact or anything but i think the eclipses sound better...thanks for the help on the sound deadener
Username: Glasswolf
Post Number: 6585
that Ti is a top notch sub.
Username: Kenwa
Post Number: 66
How would 2 Ti 12s sound in a sealed box? Is there anyhting that would be louder in a sealed box?
Miami, FLORIDA USA
Post Number: 97
theres subs thatll get louder in that box but they wont sound better tha the ti
Username: Kenwa
Post Number: 68
yeah but im going for SPL only so what would be louder than than the 12 inch eclipse Ti. The subs have to be 12s b/c i dont have room for anything bigger.
Miami, FLORIDA USA
Post Number: 103
only sub i can think of is the re mt
Username: Glasswolf
Post Number: 6633
RE MT, Ti Pro from Eclipse, DD9915 perhaps..
there are a number of good SPL targeted subs.
