Re vs Alpine
Username: Smpd357sig
IM looking at 2 12" type R's in a Powered 4 Sound double shot or 2 15" type r's in a regular box, Or 1 15 RE X-X-X in a SS. Where can the X-X-X be bought? Is there a warrany? Whats has the best SQ and SPL in a SS? A 15" type R or 15" X-X-X?
Username: Hdubb
Farmington, Nm Usa
Post Number: 101
www.reaudio.com
the X.xx is a better sub in sq and spl, in my opinion. i believe it has a warranty. im not up to date on the snailshells though. try emailing them im sure they can answer that
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1124
oh man..
the triple x hands down would be loudest and cleanest sounding sub - type-r's cannot come close to comparing, although the type X can..
would an MTX 801D power an X.X.X? if not what what should I use that is not super expensive?
Username: Joe718
Brooklyn, NY
Post Number: 275
You would be under powering the sub by a couple 500 watts
Username: Hdubb
Farmington, Nm Usa
Post Number: 104
not too familar with mtx amps but im sure it would. just make sure the amp you get is one ohm stable. it will be able to handle more power. try orion amps not sure which model but i know they make amps that are .5 ohms stable
Hfl, Ny Usa
Post Number: 1150
the thunder801d is only 2 ohm stabel, i would recciomend a bp600.1 and underpowering the sub, yes...
put in the right box you wont need more than 600w rms and people need to realize power ratings are THERMAL not mechanical...you dont need exact power ratings
