Help with my sub box!!! How to seal?
Username: Klone420
Post Number: 14
I have two 12"s in a closed box but its nowhere near being air tight, how can I fill in the gaps to make it air tight?
Username: Eric77
Post Number: 13
Silicone caulk is supposed to seal it. I dont really know exactly how to install it, but I would really like to know seeing how I am building a box tomorrow. Anybody that knows how please fill me in.
Username: Press1
Yuba City, CA USA
Post Number: 25
Just take the silicone and run a bead of it at every seam. You can use your finger to smooth it out and ensure that it has penetrated into the cracks. If you are building a box from scratch, I recommend putting a small bead on the joining edges before you screw them together. This adds strength to the joint.
liquid nail is also a good for running the bead, another idea to insure its sealed air tight is to buy a can or two of spray in truck bedliner and spray that inside the box. Its not much and always makes me feel more comfortable when building the box
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1159
eh...caulk does the job
or you can use uber amounts of glue when building the box...thats normally what i do because its too hard to go in the port and caulk it up while in the building process
Username: Eric77
Post Number: 17
SO what is the order when building a box? clamp wood together, then glue, then screw in screws? Thanks.
Username: Mr_kebo
Albertville, Al USA
Post Number: 80
I say Glue, Clamp,pre-drill holes, then put the screws in. After that i take some silicone and line all the cracks from the inside, If its a tight squeeze just use your finger.
Username: Businessboy
Post Number: 72
pre drill holes, glue - ALOT, screw it all up - dry- silicone seal it.
