Xstatic BatCaps = Battery and Capacitor in one or both!!!
Username: Suleman36
Post Number: 67
i just got my Model 800 stereo battery from ebay. Its suppose to be better then capacitors and used as 70% battery and 20 % cap. I hear really good stuffa bout them and got a big time recommendation. I got it from this guy on ebay. Great Seller http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18796%26item%3D5751833247 %26 Check it out..forget wasting money on caps when you can buy this. Problem sovled!
Username: Suleman36
Post Number: 68
Excellent Replacement and out performs even a yellow top which i have used in the past. Just wire them with your amps in the back and your set. The 400 model is nice too. Check it out guys...very much worth the money
Username: Rob315
Cuse, NY U.S.
Post Number: 133
d*amn!!!...175 for a battery??thats crazy....it better be giving me one h*ll of a blowjob for that price..
Username: Sancho886
El Cajon, CA US
Post Number: 78
yeah mo i bought a model 800 off the same guy and it works great. way better than a capacitor.
Username: Suleman36
Post Number: 69
Roger you know it!!! check it out guys
Username: Jrz126
Erie, PA USA
Kinda expensive...I'd probaby just go with a yellow top or something. As of right now though, I just put up with the dimming lights
Username: Treeguy2oo4
Phoenix, Arizona USA
Post Number: 7
man get the CAP it will help with youre amps power out put , when it hits that low bass... you get what you pay for so look around!!!
