Amp for 2 12" Id max of or x.x.x.
radar22
hi,
I need to know what amp would power 2 12" versions of either the id max or x.x.x. The x.x.x. would be a dual 2 ohm and the id max would be either a dual 2 or dual 4 depending on whether or not i use one amp for both subs or one amp per sub. I am looking to put 800-1000 watts a piece. I can spend up to $600 maybe more on amp.Also who makes a good sealed box? Thanks for any advice!
Username: Karthalin
Tacoma, WA USA
Post Number: 9
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5734880228 %26
that one is refurbished, but i ahve boughten Rockford from this guy before, amps work perfectly.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64572%26item%3D5735062729 %26
another good quality used one. Its a good amp, runs around 800$ new I think, I couldnt find any new ones. Also check out
http://www.cardomain.com/shoptype/Subwoofer+Mono+Amps
go there, do reseach to find which amps are rated at 1000W at the impedance you want, themcome back here and do a search for that amp and see the opinions of people. Pay attention to Glasswolf and Jonathan, they know their shiot
