Power acoustik
Username: Danny525
just wondering if anyones has heard or knows how good of a brand this is. All good reveiws i can find but i just got a hard time beileving you can get a 1500 rms sub and amp to fully power it for under 500 bucks.
Help2
Its less than average equipment.
along the same lines as audiobahn.
stuff is decent, but not reliable
Username: Zacdavis~
Post Number: 285
hes right, but... the class d amps they make are remarkable, other than those, i'd agree with help2 as they are kinda cheapy
ThatGuyYouKnow
heres a nice review about this amp (A1800DB)
URL: http://www.cardomain.com/item/POWA1800DB
"OK I HAD TO WRITE A NEW REVIEW! THIS AMP JUST MADE MY AUDIOBAHN AW1006Q CATCH ON FIRE! I MEAN POWER! I SMELLED SOMETHING BURNING AND IT WAS MY CAR WHAT THE HECK! I WAS PUTTING 1,100 WATTS RMS @ 2 OHMS TO A 900 WATT AUDIOBAHN AND IT WAS PUSHING FOR A MIN. UNTIL IT BLEW!!! IF YOU WANT AN AMP THAT DOES NOT QUIT MAN THIS IS FOR YOU VERY INEXPENSIVE AND ALOT OF BANG!!! WELL TODAY I HOOKED UP MY NEW SUBS TO THE AMP AND MAN THIS AMP MADE EVERY NOTE PLAY THROUGH! I MEAN I FELT THE NOTES AND THE PEOPLE INFRONT OF ME FELT IT IN THERE FEET AND TURNED AROUND AND GAVE ME A THUMBS UP! I HAVE TWO PIONEER TS-W255DVC'S @ 600 WATTS RMS @ 4 OHMS WITH ALL GAINS AT HAVE WAY, AND THE SUB SONIC AT HALF AND MAN THIS AMP IS CAUSING THESE SUBS TO HIT LIKE CRAZY... IF I HEAR CORRECTLY THESE SUBS ARE HITTING 139 DB EASY WITH ALL MY BASS ON MY HEAD UNIT TURNED DOWN AND THE BASS METER ON MY AMP HALF WAY DOWN!!! DEFINITELY A WONDERFUL AMP TO PUT ON ANYTHING... DON'T JUST GO BY THE NAME AND GET THIS THE SUBS ARE HARDLY EVEN MOVING!!! THE SOUND IS UNBELIEVABLE!!! LADIES AND GENTLEMEN IF YOU WANT A AMP THAT WORKS MAN THIS IS FOR YOU... THIS AMP WILL WORK AND WORK AND WORK AND IT DOESN'T EVEN GET HOT!!! GREAT AMP I SUGGEST YOU BUY IT, I GOT MINE FROM SOUND DOMAIN!!!"
I swaer half the people on the net have a broken caps lock key, I bet they all dont hold shift...
Username: Deathshadow
Post Number: 323
rofl my amp had a 5 star rating too before it burned up on me 2 weeks later.
Username: Oleg
Santa Monica, CA USA
Post Number: 76
My amp's wired at 1ohm, hardly gets warm. A2300HCT
