JL Audio 12W7 Sub
Username: Swampmice
Fort Worth, TX US
Post Number: 7
Any help would be welcomed. I was given a JL Audio 12W7 Sub. I am looking for an Amp to push the speaker. I have two MTX 6001 amps already. Will this be good or should I go a different route?
Thanks for the help earlier Oleg Ni
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 200
JL 500/1 will push it fine. 1000/1 is a little much, and not always needed. IMO the mtx will be a little lacking. The W7 is 3 ohm so the mtx will only be putting out about 400 watts rms. I would give it a try and if you feel it should hit harder, try out the 500/1.
