Larger subs have two terminals. Why?
j brower
I was wondering my my 15"s have two places to hook up wires, and If how I should hook them up. Thanks, Jeff
Username: Lostnconfused
Far Far Away, I Forgot USA
they are DVC subs.
Username: Jwbulger79
Florida
Post Number: 51
Dual Voice Coils - on hookup treat like two seperate subs.
http://www.crutchfield.com/S-JS9R4BRTdT1/tech/kb296.html
Sample diagrams:
http://www.crutchfield.com/S-JS9R4BRTdT1/tech/kb1158.html
ThatGuyYouKnow
wow i thought I'd never see the day.
Florida
Post Number: 56
what day is that?
Username: Jdc
Post Number: 28
man some people on this site are really smart
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 193
Can I ride in the bus with the cherry flavored windows mommy? No not that one, the short one with the special kids.
j brower
thanks for the help j.w. and mallory. Im new to this stuff and i'd appreciate if you guys keep your smart remarks to yourselves.
Username: Hdubb
Farmington, Nm Usa
Post Number: 102
im sure that not that many people knew what they were talking about when they first started car audio. it is all just a learning exp.
"Can I ride in the bus with the cherry flavored windows mommy? No not that one, the short one with the special kids." now thats funny, unapropriate but funny.
cut him some slack. i think the best way to avoid this kind of situation is to try to find it out by yourself, forums do make it easy though.
if you would like to learn alot about car audio read www.bcae1.com
very helpful, long though
Florida
Post Number: 59
i'm lost. i wasnt trying to be a smart a@@ at all. im sorry if i came across like that jeff. i am also new to car audio and have learned a lot from this board. i was just trying to share a couple of resources that i have found to be useful. i'm all about researching and having different points of reference; i can't share much from personal experience so i try to share sites that i have learned from. bcae1.com is one of my most read sites. no disrespect bro.
thedude
He wasnt talking to you.
Username: Wojopro
Post Number: 17
Yeah! Negativity is fun!
thedude
Idiocy is "funner"
Im sure you know all about that.
Username: Carguy
Post Number: 536
Hey to the new guy, the DVC may have 2 terminals but that doesn't mean you treat it as 2 separate speakers. If fact, you have to use them as "mono". If not, you run the risk of damaging it. The currents in those 2 coils have to move in same direction.
j brower
J.W. I wasnt speaking to you in the second sentence in my post, i was just thanking you for your help.
Right now i have the two terminals on each sub hooked up together and i run one set of wires to the amp.
Username: Carguy
Post Number: 548
That's good. You're using it as mono. Some people hook 2 channel amp to each coil and then use it in stereo. That will surely cause damage. Two different current in the coils will cause the cone to move in different directions. At high volume, it will either burn out the VC or do some cone damage.
Florida
Post Number: 65
oh, my bad dude. thanks for the correction isaac. i was unintentionally sharing some bad second hand advice. sorry bout that. will be more careful next time.
