Amp + sub combo [GLASS]
Username: Datboyp
Odessa, TX USA
Post Number: 10
I've got a JBL BP600.1 amp, and am going to buy two Alpine Type-R 10" subs. What would be better, the 4ohm or 2ohm subs?
Username: Avalanche
Post Number: 50
If you don't mind me answering this question I will.
Output 4 Ohms: 300W x 1
Output 2 Ohms: 600W x 1
Signal-to-Noise Ratio: >100
Frequency Response (±3dB): 20Hz - 500Hz
Total Harmonic Distortion: 0.1%
Input Sensitivity: 250mV - 4V
here are the specs of your amp.
I would buy 2 4ohm subs and run them parallel to get a 2 ohm load on the amp and get the most power out of the amp.
Help2
Dual 2 ohm version in series/parallel.
gives a 2 ohm load, and approx 300wRMS per sub
Help2
they dont make type-rs in SVC Land...
but you had the right idea
Username: Wojopro
Post Number: 16
Buy the 4 ohm version like Land says.
Help2
If you get the dual 4 ohm version
you can only run at either 1 or 4 ohms.
I see no point in that.
care to explain yourself?
Username: Avalanche
Post Number: 53
Im sorry I did not reallize that they were dual voice coils My Bad. What I meant to say is that if they were SVC to purchase 2 subs at 4 ohms and Parallel them to make a 2 ohm load on the amp Bridged to be exact.
Username: Carguy
Post Number: 528
I'd get 1ohm stable amp instead. You'll get many more choices with it.
Username: Carguy
Post Number: 529
I know it's off topic, but it was for future amp buyers :-)
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 280
the bp600.1 is 1ohm stable.
it puts out ~600wrms at both 2 and 1ohm
