Head Unit/Amp compatibility - HELP
Username: Shit4brains
Australia
Hi all
I have a question about preouts on the CD player I just purchased from ebay and their compatibility with the input sensitivity of the amp I also purchased from ebay (both yet to arrive)
The CD player I purchased from ebay is a Pioneer DEH-P9650MP (http://www.pioneeraus.com.au/car_entertainment/cdtuners/dehp9650mp/index.html) and the amp is a JBL GTO 2000 (http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem%26%26item%3D5733435832&ssPageNa me=STRK:MEWN:IT). In my haste I didn't do quite as much research as I should have done. After reading a couple of things in your forum (and having a look at this link I found in your forum (http://www.bcae1.com/gaincon2.htm) I realized I may have a problem. The Pioneer head unit preouts output 6.5 volts, and input sensitivity of the JBL amp is 250mV to 4 volts. Will this be a problem or can I rely on resistance in the wires to lower the voltage to the 4 volts? Would the amp have some sort of internal resistance on the inputs that would do this automatically? Is there any way I would be able to get around this?
BTW, I was looking at using the amp to drive a 12" eclipse sub (can't remember the exact model). I'm not getting it from ebay.
Any help/comments/advice would be much appreciated
Thanks people
Phil
Wayne100
I just hooked up an old alpine 3554 to my eclipse 5341. 2.7v out on eclipse and 500mv to 2v input on alpine, no problem.
Australia
Yeah, chances are that it would work. The thing is will I damage something after long periods of use?
When I go to the following website (http://www.bcae1.com/gaincon2.htm) and type the different things into the calculator it pops up with a message saying "Turn it down! You're gonna blow my speakers :-) If you want more power lower the impedance" and in the calculator the signal status box says "CLIPPING". This is what I am worried about, I don't usually turn my stereo all the way up but on the odd occasion I do. Will I damage my sub? Of course, I'm assuming I've typed everything into the correct boxes of the calculator.
Cheers big ears
Phil
