Need help wiring .......please
Username: Spellman21
I just purchased a 4 channel amp ...the specs are
800 watts bridged max, 2 ohm stable stereo
4 x 85 watts into 4 ohms RMS,
4 x 105 watts into 2 ohms RMS
I am confuseed on how to wire the speakers to the amp. I have 4 speakers each with 4 ohm imped. If i wire them all in parallell than the imped is 1 ohm....which is too low? and if i do all in series its 16...what should i do? please help
Username: Oleg
Santa Monica, CA USA
Post Number: 18
4 speakers, not subs, right? You don't need to parallel anything, just connect each channel to the speaker, that's it.
