Fuses keep blowing in amp
Username: Daddyluv02
Post Number: 7
I have a JBL 600.1 amp and I keep blowing the fuses. Do I have the wrong fuses in or something because it came with 30a fuses? Or is it something else. Thanks
Username: Joe718
Brooklyn, NY
Post Number: 239
that amp requires atleast a 60 amp fuse from the battery because it has 2 30amp internal fuses
Post Number: 9
Well, I looked at the specs on line and have a 1200 watts power kit and it says that the fuse included is 100a. If this fuse blew, would the amp still work? If this situation is not feasible, what else could be the problem?
Username: Joe718
Brooklyn, NY
Post Number: 245
that amp shouldnt pop a 100 amp fuse. I would check all my wiring. Make sure none of the wires got knicked in the instillation. Like the power, remote, and patch cables.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5977
if you blew a 100A fuse, you either have a dead short inside the amp and it needs to be replaced or repaired, or you have a short in the wiring somewhere causing the fuses to blow.
Post Number: 10
Is blowing the fuses in the amp hurting the amp? Also could it just be my luck that I had two fuses go out if it does not happen again?
