Like
Opinions on my setup and recomendations
Username: Thumprms
DaltonUSA
Post Number: 58
Opinions on this sub and amp setup.
15'' Rockford fosgate HX2
15" SUPER BASS UNIVERSAL W / PORT by Probox
http://www.proboxrocks.com/superbass/115SPB.shtml
Jbl BP600.1
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1098
i would chose a different box than that because the port on a side other than the front of the sub can create port noise and it can reduce the bass you get
also, i would consider a different sub, like a 16kv.2 by elemental designs or a tempest or even a brahma :-)
Username: Zacdavis~
Post Number: 227
sounds like a kick azz set up to me
Hfl, Ny Usa
Post Number: 1104
do you like to disagree with me and glasswolf zac?
it always seems ur the exact opposite of me and him
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5983
lol
not a bad setup really.
I hope that box is straight ported.. and you trim the port properly for that sub to tune it.
I'm not a big fan of bandpass enclosures generally speaking.
Username: Glasswolf
Post Number: 5984
ahh just saw the url.
looks like its not a bandpass, so it should be good to go.
Username: Avalanche
Post Number: 42
the box is pretty but I'm not sure if he will have enough power to hit hard with a JBL BP600.1 If I understood it correctly. That is what you are going to use it to power the sub.
Username: Thumprms
DaltonUSA
Post Number: 62
yea, the sub is rated at 600 rms, 1200 peak, so its matched perfectly
Facebook
Shop Related Deals
Directory
