My front speakers sound crappy
i have a 95 accord (alpine 9827), i just got rid of my front factory speakers and replaced them with kappa 6.5" 63.5i....but the sound is still crappy... no highs or lows...
... even my rear factory speakers sounds 100 times better than infinity...is it the install, or do i need new wiring..
i have no amp....but will that solve my problem..
plz help...
Username: Bananakrill
Benicia, California
Post Number: 34
Absolutely. An amp makes so much difference. That set of speakers is made to work with an amp. Get a 2 channel amp that will put out 75 watts per channel. Those are good enough speakers and should sound great, not crappy.
Username: Carguy
Post Number: 462
That is a better solution but you might want to get 4 channel amp. If not you'll find out that the front will sound 2x louder and better than the rear. Trust me you will notice a big difference.
After that comes the subs and the amp. Then later, you want more power. It's a cycle that seem to keep on going but nevertheless, an enjoyable ride.
Username: Abhinavrishi
Marysville, Wa US
thank you guys
