How to get a 4 ohms to a 2 ohms loud
Username: Bass_crazy
Odessa, Mo U.S
i have two bazooka sub duil vois coil subs and one 2 channel amp how do you wire it to get a 2ohms loud?
Username: Hdubb
Farmington, Nm Usa
Post Number: 110
it all depends on of the subs VCs if they are 4ohm time two then run them in a parallel set up
neg to neg and then pos to pos, just look here
http://rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=1+woofer&WoofImp=Dual +Voice+Coil+-+4+ohms+x+2&image.x=7&image.y=10
