Better Subs?
Username: Thenewbie
Post Number: 22
is there a better sub then an Alpine SWR-1521D 15" Dual 2-ohm Voice Coil Component Subwoofer for the same price or cheaper? i want to get 4 of them should i get 15 inch or a different size
Username: Jdc
Post Number: 21
nice subs and if you have the room i would get the 4 15's
Username: Thenewbie
Post Number: 23
now what kind of amp do you recommend what would i need so thye dont blow?
Username: Trancein305
Hialeaj, Fl Usa
Post Number: 10
i powered 2 type r 1241d's and they kinda blew because they kept making a rattling noise after a week. I was powering them wih a RF 700x amp. I guess its to much power for them. but rf is awesome. i guess alpine subs have weak center cone rubber surrounding. Thats what i think made my subs rattle. But Rockford fosgate are # 1 in my list
Username: Kenwa
Post Number: 55
RF doesnt make bad amps, also look at MTX, Memphis, JL audio, and JBL.
