Infinity REF1210A
i was wondering if infinity amps are ok, and what is dynamic power?? it says Dynamic Power 1516 watts at 2 ohms is that the rms? i can get this amp brand new for bout 200 dollers and was wondering if it was worth it?
no one knows?
Username: Carguy
Post Number: 352
Infinity amps are ok. If you can get a good deal, go for it. Some companies list dynamic power rating for those that can supply 14.4V to the amp for increased output. You will find that with a good alternator and capacitor, your voltage to the amp will be around 14.4v.
The power listing should be in rms unless noted differently.
i found it, i looked at the manual and its 1300 watts @ 2ohms , thanks for the input tho,for the price im gonna get it
