Going to blow out my back glass
Username: Skrilluh
Post Number: 27
Ok I just installed my system and got it hooked up , one problem though , I cant turn it up without my back glass bending and vibrating ridiculously , im affraid its going to bust it if i turn it up any louder , and i still have 2000 more watts to add to it. So I was wondering if Dynamatt or something like it would absorb some of the stress from the glass. Any other advice is always welcome. Pre-thanks
Username: Skrilluh
Post Number: 28
Its a 1989 Ford Bronco full size xlt
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5832
I doubt you'll break the glass unless the rubber seal ring comes loose.
the glass itself takes a LOT to break from audio.
Username: Skrilluh
Post Number: 29
Yeah thats whats worrying me , it feels like its barely being held on the inside , but oh well if i do blow it out , ill just get a new one lol thanks glass
Username: Glasswolf
Post Number: 5910
It takes a lot to shatter safety glass from sonic resonance, but what I have had happen before is that the pressure inside the cabin can pop the glass out of the weather seal holding it in on some vehicles.. Had it happen with hatchbacks mostly when the subs are right under the glass.
You can see if a glass shop has any ideas for sealing the glass more securely though.
I'm not with it today.. I think I have a cold.
heh
