New member Username: OtashPost Number: 1 Registered: Nov-04 | does any body know how to hook up new amp without taking off factory(infinity gold)? Do i hook it up to factory amp or to player? I have a mono amp that will be used only for subwoofer. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5712 Registered: Dec-03 | you get a Metra adapter harness that taps into teh factory system and gives you a set of RCA pre-outs to use for the amplifier. That's the only good way to do it. www.metra-online.com |
New member Username: OtashPost Number: 2 Registered: Nov-04 | where do i hook it up? to player or to factory amp? can u give me the full name of this adapter? |
New member Username: OtashPost Number: 3 Registered: Nov-04 | is it Metra Amplifier Integration Wiring Harness Adapter? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5731 Registered: Dec-03 | yes |
New member Username: OtashPost Number: 4 Registered: Nov-04 | where can i find it? everywhere i look it is for ford models. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5738 Registered: Dec-03 | any car audio shop should be able to order one or have it in stock. you could try through metra-online or partsexpress.com or similar as well. |
Help2 Unregistered guest | Is that a LOC or something... never heard of the metra. A LOC will work most likely too. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5746 Registered: Dec-03 | Help2, the Jeep's premium system is similar to the Bose and Mach systems. It uses amplifiers in the stock system, so a line reducer is required to get a clean line level signal. there is a harness sold that splits off the factory amp harness to provide the proper RCA line outs for adding an amplifier and subs to the factory system. |
New member Username: OtashPost Number: 10 Registered: Nov-04 | does anybody know what kind of amp do i need for pioneer sub (450 w max, 150 nom)? does sony XPLOD XM-2100GTX(600 Watts 2 channels max 100 watts RMS x 2 at 4 ohms 125 watts RMS x 2 at 2 ohms 250 watts RMS x 1 at 4 ohms stereo 2 channel or bridged mono 1 channel output 4-ohm stable in bridged mode Tri-way capable MosFET power supply low-pass crossover preamp and speaker level inputs preamp outputs variable bass boost (0-10 dB) centered at 40 Hz) go okay with it? |
Bronze Member Username: OtashPost Number: 12 Registered: Nov-04 | and what would be the remote wire from amp be connected to? does my system has an out for it? |
