Quick Question bout Sub install
Alright I have:
2 12" xs-L1290X subs, Peak Power: 1500 Watts, 75 Oz. Magnet, 5 Sided Polyethylene Cone, Rubber Surround w/Stroke Stabilizer, 4-Layer Edge Wound 4 Ohm Voice Coil i can't find the rms...,
500w 2 channel xplod amp
4x100w @ 4Ohm (MAX) 2x125w @ 4Ohm (MAX)Selectable High/Low Pass Filters 80Hz Frequency Response 5-50,000hz 4x50w @ 4Ohm (RMS)2x50w @ 4Ohm (RMS) MOSFET Power Supply2-Ohm Capable .
what would be the best way to hook these components up?
thanks in advance
-mike
Username: Jmloughrey
Farmington, CT
Post Number: 439
i wouldn't reccomend that amp for subs, sounds alot more like an amp you'd want to connect to some compnents
gmc suburban 94
so what kind a amp are you talking about?
and is it still possible to run those subs off it, or is that a bad idea.
