Whats the difference in sound between a banpass box and reg.
aimjunkey
i have 2 4OHM 1200watt(RMS) cheep legacy 15"'s and i need a box. I want to buy a new bandpass box because it looks nice and i want to know if the sound quality is worth the price difference in a bandpass and a regular 15" box.
Sucubus
Depends on what you mean by sound quality... A prefab bandpass box will make your speakers sound worse...louder, but worse. But those subs arent doing you any favors there either ;)
bandpass enclosures serve one purpose. efficiency. they're loud. they don't hit that deeply, and their range is limited. if you want deep bass, you want to go sealed or vented.
