Adding another amp need help
Username: Smitty64
United States
hey is there any way to hook up two amps? and if i did hook up two amps would i need a strike cap (compasator)?
thank you,
Kyle
Username: Carguy
Post Number: 245
Hey Kyle, that'll depend on the 2nd amp's power. Your stock alternator can handle only so much power. If they both total around 450W rms, then it should be okay. Adding a capacitor will give you a tight bass and less light flickerings. Just make sure you have good ground for the amps.
Username: Smitty64
United States
k thanxs i will have more questions later or should i just get a 400W amp and also hook up my 200W amp???
Username: Crazy3rdgen
Long Neck, Delaware U.s
Post Number: 40
do the amps always have to be the same brand for example.. i hook up 1 brahma 12 to a jbl 1200.1 and also a rf1001bd for 1 vr comp 15" 500w at 4 ohms would this work? 2 diff kinda amps
Username: Carguy
Post Number: 263
No Sean, the amps can be any brand you like. As long as you have enough power for them, you're fine.
Username: Carguy
Post Number: 264
Hey Kyle, as long as you don't plan on maxing out the amps, you should be okay.
