Cheapest place to get a brahma 12 someone said ebay but i dont see it
Username: Crazy3rdgen
Long Neck, Delaware U.s
Post Number: 18
Sucubus
You cant get them much cheaper than directly
from Adire unless theyre used.
Post Number: 20
yeah but where from? : (
Username: Hdubb
Farmington, Nm Usa
Post Number: 28
http://www.acoustic-visions.com/~acoustic/products/subwoofer_drivers/adire_brahm a/ here is a site
Post Number: 21
Brahma 12"=$379.00 anywhere cheaper? i'll try searchin also
Username: Hdubb
Farmington, Nm Usa
Post Number: 30
it wont get much cheaper, used ones usually go for 300, on that website its 379 shipped, no shipping costs which is hard to find
Post Number: 22
yeah thats not too bad i take consider i had kickers it is lol lets see 120 sumtin a sub or 380.. i hope this brahma 12 will thump ported with a 1001bd amp pretty nice.. can i wire 1 12" brahma at 2 ohms? cause my amp is 1000w at 2 ohm 500 at 4ohms.. ?
Username: Hdubb
Farmington, Nm Usa
Post Number: 31
the brahma will hit very hard, and even harder in a slot ported box. http://www.rockfordfosgate.com/rftech/wiringwizard.asp check out this site to see how to wire to your needs
Post Number: 23
yea i always go there its a great place i just wasnt sure if it was the same for the brahma
Username: Hdubb
Farmington, Nm Usa
Post Number: 32
yeah the brahm is a dual two ohm so either one or 4 ohms, is your amp one ohm stable?
Post Number: 24
see when i went to order the brahma it didnt ask me any info like what ohm i wanted,.. so i take it they only come in 1 certain ohm?!?
Post Number: 25
FCK MY AMP IS NOT 1 OHM STABLE..FCUK.. ONLY wireing it at 2 ohm will give me 1000w
Username: Hdubb
Farmington, Nm Usa
Post Number: 33
yeah they only come as dual 2 ohms, running one of these at four ohms they will still sound nice
Username: Hdubb
Farmington, Nm Usa
Post Number: 34
you wont need too too much power to make these sound nice, i think it depends on how big the box is too, check adireaudio.com to be sure
Post Number: 26
i wanted 1000 watts to it im totaly fcked just forget everything
Username: Hdubb
Farmington, Nm Usa
Post Number: 35
calm down just look for another sub. i think running a brahma at 600 watts would probably sound better than a lot of subs at 1000. thats my opinion though. your going to be ok. lol
Post Number: 27
no brahma at 500... its just not gunna be as loud as i wanted...sht messed up everything
