Good clean loud highs...JL or Kicker?
i was comparing component sets like JL TR and Kicker K series... for example the TR650-csi or the k65.2 .. which would be louder, cleaner, and better... amp is JL 300/4 ...if you would go anohter way let me know too thanks i appreciate it. ..also keep inmind price... ebay has k65.2 at $100 and TR650-Csi at $160... i would not like to go any higher.
CORRECTION!!! im sorry the JL's are the VR series... thats VR650-Csi NOT TR sorry about the confusion
Username: Kev7706
Post Number: 9
"Louder, cleaner, and better"...very hard to tell. Cleaner and better are subjective terms. If you want better overall accuracy and natural sound, JL is the better choice. However, the Kickers would be louder. I would go the JL route-----quality over quantity
Username: Spittin2rock
Post Number: 77
either way you're getting a nice set of highs
