What kind of amp is best for me?
Username: 1964econoline
Beaverton, Oregon Usa
I have 8 subwoofers. Max watts is a little under 4000. Rms is about half of that. What would a good amp be for my situation?
Username: Hurleyblink187
Post Number: 11
hah i wouldnt worry bout an amp at the moment but a couple of yellowtop batteries in your trunk first.. not to mention a h/o alternator swap but match rms. with rms of amp.. dont have to be exact just try to not go over the rms, you probably will need 3-4 amps to push your (8) subs..
Username: Thrust
Post Number: 49
tell me more about the subs, are they dvc? 4 ohm? what?
im not an expert at subs or any of this so i couldnt answer your question tim. Shawn, how do i connect amps?
Username: Thrust
Post Number: 56
they should say right on them what ohm rating they are. if they have 2 sets of connectors then they are dvc (dual voice coil). Is it possible to do research on your subs via google search??
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5800
please provide make and model of the subs, along with the number of coils per sub and ohms per coil.
thank you
