2ohm + 2ohm ???
Username: C12698
Oklahoma
If I have a subwoofer (alpine 1221d) that is a dual voice coil (2ohm + 2ohm) and my amplifiers rms rating is 230 watts x 2 @ 2ohm's, will this sub actually put out like its gettting the 230 watts from the amp or will the sub only be puting out half of the 230 watts that its receiving because its a dual voice coil?? I hope that made sence.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 43
You should be able to put 230watts on each voice coil, but you will have to wire each voice coil into its own channel on the amp.
