Subwoofers Poping?!?
Username: Djflipnautikz
Miami, Fl United States
Post Number: 11
OK...everytime i turn of the car my subwoofers go "POP" when i lower the volume all the way down 2 0 the subs go "pop"..what is it and how can i fix it?
Username: Elecgenius
La Puente, Ca United States
Post Number: 130
although i could be wrong, it seems like its a problem with ur wiring. that happened to my system before on a different vehicle when a my cousin put in new carpeting and accidentally put a screw trhough one of the rca's. i would still hear sound, but the rca was being grounded with the vehicle. it might be a variation of things. i would suggest u thoroughly inspect ur wiring and check for malfunctions first.
Username: Dontavious89
Laurens, SC USA
Post Number: 34
It could also be your amp,This happens to alot of the cheeper amps(I'm not sure what amp your using)Or you could just have a bad ground on your amplifier.
Post Number: 12
i have a 800.2 RF
peter griffin
I've got an older rf amp powering my components that does the exact same thing. i was told its from it not having a soft turn on circuit but i'm not sure.
Sucubus
Its normal...
called "turn-on pop"
I have no idea why.
Username: 54danny54
Post Number: 36
Sucubus is right and wrong...it could b that the amp is 2 powerful
