Amp for 1 kicker s12L5.
lvloises305
I was wondering which amps would worl best with this sub. Also I need in understanding what ohms are exactly and how this affects the power supplied from the amp to the sub. Thanks
Username: Capulina6
Post Number: 42
basically ohms = resistance. the more ohms,the more resistance there is and the less power your amp can put out due to high resistance. the less ohms there is, the less resistence there is, allowing your amp to put put more power. amps are usually rated for 4 and 2 ohm use and a few bigger amps are rated all the way down to 1 ohm. so your sub is either a dual 4 ohm version, or a dual 2ohm version. depending on how it is wired, it will present a different ohm load. remember the less resistance there is, the more power output the amp can put out. to suggest a good amp, we need to know how many ohms the voice coils are, so let us know and we'll help you out with what we can. i hoppy i didnt confuse you, im not a great explainer
lvloises305
dual 4-ohm voice coils for wiring flexibility
frequency response 20-100 Hz
power range 50-600 watts RMS (300 watts per coil)
peak power handling 1,200 watts
sensitivity 87.3 dB SPL
Those are the features and thanls for clearing that up for me
