Which one is better?
Username: Lighting_boy
Post Number: 18
i made a list of sub, about same power toghter
3x mtx 8000 12"
1 kicker l7 15"
2 kick l5 15"
adire brahma 15"
3 infinty perfect 10"
3 Image Dynamics 10" v3
1 rockford fosgate power stage 2 15"
ill power them with the amp that have the max rms watt of the subs. and ill put them in their recommend box volume, so whit will be better?
Username: Audionoob13
Novi, MI USA ...
Post Number: 77
everything except the Adire brahma and IDmx sorrts low end in my opinion. and you need to read up on proper powering of the brahma if you get one. becuase most newbs will power it at 1600Watts which is bad. the idmax is about a 1000watts.
Post Number: 19
how much can i put in the brahma?
Novi, MI USA ...
Post Number: 78
depends on the encloser. if its a big ported encloser, try 800-1200 rms power. i got a 3.0 Cu Ft vented to 28 HZ and its powed at about 1000watts.
Post Number: 21
i c the 3 iq 10" v3 will give more sq and adire will give spl, is that right?
Username: Slap_johnson
Arizona
Post Number: 102
u really only need to give a brahma 600-800 watts to reach X-Max
