Amp fan??
Username: Hurleyblink187
Hey does anyone know how i would wire a fan (small cpu size amp)into my amps power cable? or do you fun it from the fuse box??
I guess it would be good to tell you im going to run a soundstorm amp 500x2 to put this fan in, to one Audiobahn AW120T, aint sure if i can bridge this amp since the speaker says it only had one 4ohm voice coil. the amp is 2-ohm stable
Username: Carguy
Post Number: 198
Hey I put a cpu fan in my Jensen amp. It works great. What I did was to open up the amp and borrow one of the power terminals inside and attached the fan. My amp had mini plugs for the light display on the amp, so I used that.
I also cut into the case and made a vent.
