Amp and speaker wiring
Username: Hurleyblink187
Post Number: 7
umm im about to purchase a Audiobahn AW120T sub, along with a sounstorm 500x2 amp, just a question, when i go to bridge the channels doesnt that give me a 2ohm impendance. or it doesnt matter as long as you have the sub wired at 4 ohm, the Audiobahn AW120T is single 4-0hm voice coil. just wanted to make sure this would work out before i bought this.
Username: Thrust
Post Number: 16
technically it is a 2 ohm load to the amp, however if the manufacturer says the amp will work mono (bridged) into a 4 ohm load them you should be fine. And I've never seen a bridged amp that won't push (1) 4 ohm speaker
