Need help to hook up amp with speaker
Username: Exoticlov3r
Hello everyone. Anyone know how to hook up sony xm222w 2channel to 2 6 1/2 front speaker and 2 6x9 rear speaker. The instruction i had was lil confuse so i need some help yall. Thank u very much
Username: Carguy
Post Number: 177
Hey Cu Bu, that Sony amp sucks first of all and it's only a 2 channel. You can either connect it to the front or rear speakers. If you want to power all of them, then get 4 channel amp.
If you HU has rca connectors, use that, if not get speaker level to rca converter.
Username: Thrust
Post Number: 8
If that amp is 2 ohm stable you can hook up left (front & rear) to one channel and right (front & rear) to the other channel. Won't be able to fade front to rear, but hey, they will "all be hooked up".
Username: Carguy
Post Number: 179
Whoa, well could do that but would it be worth the time and effort?
here'sjonny
if the speakers are 2 ohm stable and so is the amp, you could hook up the front left and rear left... in parallel. This, however, would take a lot of speaker wire and wouldnt be optimal. Your best bet if you can spare the cash is to pick up a four channel amp. To hook the speakers in parallel, run a 2 wires from each channel to the rear two speakers, then run another wire from the speakers to the corresponding +/- on the front speakers. Wire left with left and right with right. Make sure the amp and speakers are two ohm stable or you'll be out a few bucks. the speakers probably are not.
