Tuning amp and box crack
Username: Ha_split_lf
Post Number: 21
I just installed my zapco 500.1 and its hooked up to my jl 12w6v2 i have the subs wired at 2 ohms and now im trying to figure out what im supposed to do with the screws tuning frequency and sub sonic i believe. I have the sub in a sealed box and right now it sounds alright but im pretty sure i need to tune the screws as i have already tuned the gain now i just want the sub to sound better. Also i noticed there is a hole where the sub mounts and it isnt completley sealed could this be bad for the sub or make it hit differently or not as powerfully im deciding if i should try to fix teh small hole or buy a new box. im pretty new to doing my own installs so any help or thoughts would be appreciated. thanks in advance.
