I Need Help!!!!!
I just bought 2 12" JL Audio W6V2 subwoofers. Here are the specifications for it:
Nominal Diameter: 12 inches (300 mm) Continuous Power Handling: 400 Watts Voice Coil: 2.75" diameter, 4-layer, Kapton former Available Configurations: Dual 4 ohm only Xmax (one-way, linear): 0.65" (16.5 mm) Sealed Enclosure Range: 0.90-1.50 cu.ft. (25.0-42.0 liters) Ported Enclosure Range: 1.25-1.75 cu.ft. (35.4-49.5 liters) VRC Technology: YES W-Cone Technology: YES Elevated Frame Technology: YES Floating Cone Attach Technology: YES NeckVent Technology: YES
HERE IS THA MILLION-DOLLAR QUESTION. WHAT TYPE OF AMP(S) DO I NEED TO PUSH THIS???????
I WOULD REALLY APPRECIATE IT IF SOMEONE HERE COULD SEND ME AN EMAIL TO ANSWER MY QUESTION AT:jman28025@hotmail.com
Username: Carguy
Post Number: 110
Hey Jessie, you need to get an amp that's 2 ohms stable to drive them to the max.
I'd invest on a Class D amps from Audiobahn, MTX, Kicker, and MA Audio.
