Reducing output on one set of speakers
proxybox
Hi, I have a four channel amp that feeds front and rear speakers. What is the best way to reduce the output to the rear speakers. I have read that I could use an L-pad to passively reduce the output and have some control. Are there any other methods that I am not aware of?
Thanks,
jon
los angeles
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5587
yes.
it's called the "fader" on your head unit.
proxybox
The fader will not work since I have the four speakers connected to the single amp. I used the other low level output to another amp which drives the subwoofer. Therefore, the fader will only switch between the four speakers and the sub. I need a way to reduce the output on the rear deck speakers to balance the staging.
jon
Username: Ps1k0
Post Number: 47
so you should have two sets of gains, one set for front and one for rear. turn the rear ones down.
Username: Glasswolf
Post Number: 5609
use an external electronic crossover with level control, like audiocontrol's 6XS, or the Coustic XM3, or get a head unit with 3 sets of pre-outs
F/R/S
