Bryce, you want the loudest car? do you have at least a six figure budget for this project? That's not counting the car, I mean. just for installation and hardware, custom work, etc.
Well,I'm not wanting to spend more than $800.00 in Subs,$500.00 in amps,And $300.00 in capacitors.My uncle custom makes boxes ,so if he can find the plans,he can build any box.Is slot ported the best for spl?
ahhahaahhhahhaahaahahhahhaahahhahahahahahahahahhahahahahahahahhhahahhhahahaahhah ahahahahahhhhhhahhahhhah. sorry but i have to slam you. for spl why the hell do you need Caps. 500$ in amps ..My multi channel almost costed me 500$ LOL oh man you got alot of reading to do. so you want spl....star off buying a mini van. then make it more safe than air force one. the buy 15 15" brahmas. if you get that far i will cut my wrist.
I'll cut my wrist before I drive A fu**ing minivan,the only chick you'll pick up in that is your momma.You need to do some research some of the nicer capacitors cost alot.I have a very weak battery,so I need a cap.
Help2
No you dont need a cap. FIrst you need to do a big 3 Then you need a battery, and then a HO alt. After all that...you may want a cap, but you should never NEED one.
really capacitors are only a part of a proper charging system for a high end audio setup in a car. you may want to look at a small hatchback instead of a large minivan. much easier to turn into a good SPL vehicle. then look at some good amps, at least a pair of hich excursion subs in a good box, some very good front components, and a head unit. for events, you'll also need signal processing from soneone like audiocontrol. things to consider
brahmas are for sq/spl, not just spl....get a RE MT step up from the X.XX and is desinged for spl applacations. the adire tumult is a elite choice too. im sure theres other people that are going to give you many other options.
yeah get some MT's i sat n my friends car today who had 3 of them n there and yeah..i didn't sit n there but like 10 seconds after he turned it up..they r defiently some SERIOUS subs..he's knocked all the door handles off and the whole outter shell of the car is flexing out when it hits..
