New member Username: Datboyp
Odessa,
TX
Post Number: 7 Registered: Oct-04
Posted on would the JBL BP600.1 be adequate for these two subs, or should I go with the JBL BP1200.1? |
NorthWest,
Michigan
Post Number: 5513 Registered: Dec-03
Posted on use two 4 ohm type R 10" and the 600.1 is plenty. that's 300 watts each. they'll do great in the proper box.
Odessa,
TX
Post Number: 8 Registered: Oct-04
Posted on ported or sealed? i have a limited amount of room (single cab truck) and don't think i could go ported with two 10"s. |
NorthWest,
Michigan
Post Number: 5516 Registered: Dec-03
Posted on two ported 10" will take about 3cu ft total. not that much room really.
Odessa,
TX
Post Number: 9 Registered: Oct-04
Posted on and, the box i have designed has about .60 cubic feet of room inside it. the subs are listed as 0.5-0.8. Would this work well? |
