Power acoustic pa-10s
trying to find theile/small parameters on a power acoustic pa-10s woofer.
power acoustic list six different versions all with different prefixes.
all help apreciated.
update, found out it also has 'spectrum ferrosound' printed on the dustcap..
going to design enclosure,
if i can find specs....
Username: Deathshadow
Post Number: 173
Stay FAR! (FAR!) "FAR!" away from ANYTHING under the Power Craptastik name.
Username: Decde
Post Number: 202
LMAO!
You should trust Damien on this one Anon
Username: Elecgenius
La Puente, Ca United States
Post Number: 114
u can get a lot better than power acoustic. they dont have much sq, power, and durability. all i gotta saay is keep a fire extinguisher nearbye.
try farenheit amps if u wanna go for inexpensive but medium quality. if not go for diesel amps. lot better than power and not that expensive(depending on what model u want)
Krell
heh, yup not mine, trying to help a guy with zero $$$.
mine consists of - nak ta25, nak ec302, nak 100pa (front) nak pa 302 (sub), ads AL6 (front), pair nak sp 80.
