Need someones help
Username: Air87_05
Post Number: 9
if my amp is 250x2@4 ohms (rms) then if i bridge the amp it would be 500 watts correct? but i also want to know at how many ohms my amp will be stable at.
Username: Its_bacon12
Post Number: 70
it should probly be able to run down at 2 ohms stereo, and therefore be able to run at 4 ohms bridged, probobly more than 500w rms from what ive seen when bridging amps....
not sure, have to look at the specs for it but yes it should be more than 500w RMS x1 @ 4 ohms
Username: Glasswolf
Post Number: 929
bridged, the amp will be ~800W-1Kw @ 4 Ohms.
The amp is 4 Ohm stable bridged, 2 Ohm stable stereo.
do not attempt to put a two Ohm load on the amp when it's bridged.
